I have encountered a new problem . I purchased a Megasquirt unit from whodwho. All was well but now I have a new computer to run tunerstudio and cannot get it to connect to the ms ecu. Not sure which .ini file to run. If I run detect ports, it does detect com3 on my laptop, but I always get an error message when trying to connect to the ecu. Any suggestions?
Unable to connect to ecu with new computer Help!
Is this with a USB adapter? Make sure the driver is loaded for it and you can find the port it is bound to in Device Manager.
On the CD there is a portcheck.exe under the tool director and let it scan for it and see if it finds the controller.
Remember to set the Tunerstudio project to Microsquirt Module ;)
Thanks for the response Keith, I got your email as well but cant bring that up at work.
Yes, I'm trying to interface with a serial to USB cable. My computer supposedly automatically installed the drivers with the cable was plugged in, I will double check that in device manager tonight.
The portcheck.exe is on the driver cd or the MS cd you supplied?
When I was trying to connect last night it would not recognize MS2extra v 3.2.1 and ask that I select the other option and search for a .ini file. Should I be doing this? Which one is the correct .ini file?
I selected Microsquirt in the project menu, as you remember that has given us headaches in the past.
Thanks for all of your help!
