On top of the stock trunk ground strap
I ran a cable to a lug in the engine bay
so I can directly ground my logic level coils.
My question is,
I have enough wire to making another ground.
Should I run that to the factory ecu ground location on the strut?
Or would that put some noise in there or something like that?
I'm thinking of running it to the other strut studs or maybe directly to
the block using a motor mount..
Easy question but I'm an electrical noob.:puppy:
Here is the lug. It's inside the wiring cover.
My question is,
