help with miller maf ECU wire harness 12v signal splice/retrofit
  • ROLLingKING
    • Apr 2011
    • 1169
    i have an early model (87) 325is with a 173 ecu. i just want to make sure bmw didnt change wire colors or pins between the late and early models.
    According to miller's pdf instructions i should be taking pin 12 (grey/white) and cutting it near the connector to solder it to pin 37 (red/blue) .
    just to be clear, there will now be nothing coming out of pin 12 now. im just connecting it to a power?
    m20 is plenty. im simply a drifter.
    build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
  • ROLLingKING
    • Apr 2011
    • 1169
    [ATTACH]75656[/ATTACH]
    • ROLLingKING
      • Apr 2011
      • 1169
      theres no difference. it was an easy install
