megasquirt problem
  • giannhs84_
    • Aug 2013
    • 1
    megasquirt problem
    Hello,
    I have a BMW E30 M20 325is. I sending you these photos so that you could tell me if i put the pieces of the ECU together correctly.
    I want to ask you something related to the Jumper Configuration from these instructions http://www.diyautotune.com/diypnp/apps/b55/usdm-bmw-325-8792-m20b25-mt.html
    I dont know what the IAC - IAC IN is and where it is.
    Do i need to connect the Realay 2 with input 27 outpin 36? (i have the v1.5)
    And what does " Use an 18k Ohm resistor in series with VR+ input.
    Can be in jumper wire or proto area." mean ???
    The problem I have is that when I start the engine it seems it is about to start but it doesn't .
    Thank you in advance.
  • Bmwb
    • Jan 2013
    • 196
    looks about right but my iac isn't working so ill need someone to double check the iac aswell ... my car idles like shit everything else looks like mine
    u also should clean all that flux that's one the solders u did
    Sold Black BMW E30 325IS
    1987 bmw e30 euro part out
    1990 Bmw 325i Cabrio 2.9
    Metric Mechanic 2.9 stroker
    Holset Hx35w CXRacing Manifold
    MegaSquirt ARP HeadStuds
    OEM HG AEM Methanol injection
    20psi
