Turbo First Start Up Issue
  • Bmwb
    • Jan 2013
    • 196
    Got an issue im trying to figure out if its a timing issue or its just the fact that my wasted spark isnt giving me enough spark here is what iv done
    2.9 stroker metric mechanic baby six kit
    -885 head
    -272 cam
    -2.7 bottom block
    -holset hx35w
    -2.5 i connecting rods ,
    -block o ringed
    -cx racing manifold
    -bosch 55pin megasquirt v2/extra
    -60lb injectors from kamotors
    -diyautotune wasted spark coil pack
    -MSD universal spark plugs
    - fully regasketed
    -spec stage 3 clutch
    -ARP Studs
    -Oem Headgasket
    issue im having is it bucks but wont start yes iv looked around nothing with the same problem inter-cooler and piping was all connected this motor has not been turned on at all after the rebuild i just went straight to putting everything together and tried to crank it not i fixed my issue i had with the coils not firing idk if the spark is strong enough or not also don't know if i have the fuel lines connected right but my cylinders were soaked with fuel when the plugs got pulled out , but it bucks and almost fires up but than as it wants to fire the starter weakens and acts as if the battery has died but when its close to firing the intake backfires and basically tried ether which is bad but still back fired the ether
    here a video battery's weak and something sounds like its robbing all the power big time even with another car boosting it car hasn't been started after rebuild which is what i should of done before
    before i bent the rod just needed a mad valve adjustment
    Sold Black BMW E30 325IS
    1987 bmw e30 euro part out
    1990 Bmw 325i Cabrio 2.9
    Metric Mechanic 2.9 stroker
    Holset Hx35w CXRacing Manifold
    MegaSquirt ARP HeadStuds
    OEM HG AEM Methanol injection
    20psi
  • Bmwb
    • Jan 2013
    • 196
    Started sounds strong! , went back to a single coil the wasted spark has some issues i gotta figure out ! , the wasted spark isnt giveing a strong spark at all and isnt firing it up at all
    20psi
    • spoolinspoon
      • Dec 2013
      • 66
      You have ms set up right for wasted spark?
      Sent from my Nexus 5 using Tapatalk
      My Feedback Thread
