The megasquirt i built is supposed to be compatible with an e30 /e34.
purchased: http://www.diyautotune.com/catalog/d...kit-p-385.html
Followed these instructions / modified for wasted spark ( added 3 additional igniters): http://www.diyautotune.com/diypnp/do..._assembly.html
-No Variable TPS
-Added Innovate MTX-L wideband
-GM IAT
-Stock Coolant sensor
-Stock Injectors
First question: Are there any differences between the e30 / e34 dme pin outs? I've been under the assumption that they are the same from trollin the forums.
My issues: The megasquirt doesnt seem to be receiving power from the main relay (key turn to run does nothing). Once i apply an external power source (barrel jack) you can hear fuel pump relay clicking as well as priming injector clicks. ( works appropriately)
Seems like a dead ICV. I was able to figure out an issue with the 2500 rpm idle, but not sure what could be causing this problem (other than wiring at the unit) I taped up the intake boot with a small opening and was able to manually idle down to ~700rpm leaving me to believe the ICV isnt being actuated. Doesnt matter if plugged / unplugged -> same result
The IAT sensor functions properly (blowin my hot stank breath on it was able to make the temp rise and fall once cooled...BUT im hearin a relay click once the wire is disconnected / reconnected. (pin 1 & 4 on the AFM plug) WTF..
Car starts / runs perfectly with the megasquirt on external power plugged into the stock 55pin harness plug; Im going to be retracing the build, but since it runs fine with test, im not sure if construction and pinouts are wrong...
-No Variable TPS
-GM IAT
-Stock Injectors
