MTX-L vs Tunerstudio Discrepancies
  • megu2ice
    • Jul 2013
    • 61
    There's a difference of .5 AFR between the Mtx-L gauge and my tunerstudio gauge. Does anyone know what might be the issue? I'm not sure if this has always been the case since I've installed it but I only noticed it recently. My initial guess would be the ground for the gauge might of come loose which I will check this weekend.
    Is there anyway to sync the two and if not, which one is accurate?
    Build Thread
  • ak-
    • 12422
    Ground Megasquirt and the gauge's ground wire(s) all to the same ground. For example, the ECU ground/shock tower.
    That put my readings in sync.
    Also do your 0v - 5v settings in tunerstudio match whatever is programmed into your MTX-L?
    1991 325iS turbo
    • megu2ice
      • Jul 2013
      • 61
      The gauge is grounded to the shock tower and the 0v-5v settings in tunerstudio are set to whatever the lc1 settings are. Does anyone know the specific voltages for the mtx-l?
      Build Thread
      • ak-
        • 12422
        0v - 7.35 afr
        5v - 22.39 afr
        http://www.innovatemotorsports.com/s...rint%201.2.pdf
        1991 325iS turbo
        • megu2ice
          • Jul 2013
          • 61
          Made some changes to the calibration and its within .1 afr. Thanks for the help
          Build Thread
