m20 carb conversion
  • mikebloco
    • Feb 2015
    • 190
    m20 carb conversion
    Has anyone ever ran a downdraft carb like a weber 32/36 on an m20? Just curious.
  • SkiFree
    • Jun 2011
    • 2766
    Yes, downdrafts ..... IDFs (not any DGV's).
    ADAMS Autosport
    • mikebloco
      • Feb 2015
      • 190
      It think it would be cool to run a DGV 32/36 or 38. Throttle response would be nice. I love IDF's but spending around $1000 on just carbs is a little ridiculous
      • SkiFree
        • Jun 2011
        • 2766
        Gotcha ... there is no manifold that exists for that setup. Would be neat, but if you were having someone fab you up a manifold it'd probably start to even out price wise.
        ADAMS Autosport
        • LJ851
          • 7919
          I doubt it would be too difficult to adapt a DGV carb onto a 320/6 single carb manifold.
          Lorin
          The M30 is God's engine.
          • SkiFree
            • Jun 2011
            • 2766
            Forgot about that .... that might just work .... with some work.
            ADAMS Autosport
            • mikebloco
              • Feb 2015
              • 190
              What if I made a block off plate were the throttle body goes and then cut a hole directly in the top of the intake were the bmw symbol is. Then drill and tap some holes for 4 studs to come out. Boom! weber right on top.....although I might have to cut a square out of the hood for the air filter.........mini hood scoop lol
              • mikebloco
                • Feb 2015
                • 190
                Can't find a 320/6 manifold anywhere atm. I guess I'll pick up another m20 intake and see what I can do.
                • totheredline
                  • Jun 2013
                  • 762
                  I'm running a 4 barrel carb on my m30 using a euro manifold. They have a similar manifold for m20s too. Google m20 4 barrel manifold.
                  = Heidi 1988 325 -> 335i. 7200rpm built M30
                  • mikebloco
                    • Feb 2015
                    • 190
                    Yeah I've found some but none that are currently for sale
                    • rlich8
                      • Apr 2015
                      • 76
                      The trick isn't getting carbs, it's the manifold, and also the tuning. Webers are not plug and play. They are when they're properly set up, but very few individuals know how to actually set them up properly.
                      '71 E-Type Jag
                      '91 318iS
