Miller PSIK and War Chip - ECU wiring change?
  • Henna30
    • May 2012
    • 1494
    If you are installing the Miller Performance Pro Street Injection Kit (PSIK) AND the Miller War chip do you have to do the ECU wiring modification described in the PSIK installation manual? It involves cutting the wire for pin 12 and joining it to the wire for pin 37. The manual is written assuming you are using the chip included with the PSIK but I will be using the WAR chip in my ECU instead. I left a PM for Brody but hoping someone has already gone through this.
    Thanks
  • LJ851
    • 7919
    Yes, the wiring mod is the same for the standard chip and the war chip.
    Lorin
    The M30 is God's engine.
    • Henna30
      • May 2012
      • 1494
      Got it. Thank you.
