I recently installed my wasted spark system and I'm running into some issues. I followed this write up and I'm not having any luck.
I used the same GM 3 coil baseplate and wired it accordingly but I cannot get any spark from any of the coils. I pulled the coils off and checked what I have at each pin on the baseplate. Each coil has a constant (acc) power supply at one pin and an intermittent positive (5V I believe) signal at the other pin during cranking. I think this is correct but I'm not getting spark at any of the plugs. I can't believe that all three coils would have somehow burned out but what else could be the problem??
