Wasted spark +12V source question
  • GUERONASTY
    • Aug 2011
    • 811
    Okay so I finally got my car to start after installing Megasquirt DIYPNP. The car starts (still needs a tune). When I turn it off I hear a buzz from the coil. I'm wondering if it's because I ran its +12V power source directly from the positive battery post in engine bay? Maybe I should have it where it gets +12V for a switched power source? Is there a need to run a fuse as well just in case? I have it grounded to the ground post near the passenger side shock tower if that matters also...
    I'm running the diyautotune coil
    All it said above as far as hook up for power is to use a +12V power source.
    Thanks for the help in advance guys!
  • whodwho
    • Jun 2008
    • 1547
    It needs to be a switched source, you can use the original stock coil power.
    My take is to use that to trigger a relay for a better power source and to take the load off the ign switch and shortens the path(goes from batt post thru relay to coilpack).
    also a bit concerned of hearing anything out of the coil when not running, there should be no ground when not running.
    Not sure what you are grounding to the shock tower??
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • whodwho
      • Jun 2008
      • 1547
      Maybe a bit late but here is a pinout of the coil
      • GUERONASTY
        • Aug 2011
        • 811
        I ran a temporary ground from a designated ground post on the car to the coils bolt hole for mounting. I held it in place on the coil with a nut and bolt. I'm guessing I don't need a ground then from what then...
        • GUERONASTY
          • Aug 2011
          • 811
          Okay so now I'm going to run a relay between the coil and the +12V power source,+ battery post. Using the stock switched coil power to trigger the relay. Is that correct?
          Thanks whodwho always helpful advice!
          • whodwho
            • Jun 2008
            • 1547
            You don't need to run the relay but I believe it will give a better spark for not having a voltage drop from all the connection and a 20 yr old ign switch and a shorter path.
            de nada, Let me know if you need a diagram and I will put up something
            • GUERONASTY
              • Aug 2011
              • 811
              Aw okay got it! ...yes please a diagram would help
              • whodwho
                • Jun 2008
                • 1547
                Here is a good pic to work with, ignore the yellow
                • GUERONASTY
                  • Aug 2011
                  • 811
                  Thanks you the man! :up:
