Help with M60B40 AFR
  • 90-E34-M5
    • Sep 2015
    • 21
    Hi everyone,
    This is the dyno result for my M60B40 a few days ago.
    The engine is down on compression (150 to 170 psi) and this dyno seems to consistently under read , it's hot here and I don't think the numbers are being corrected but the dyno operator says it is.
    I burned a new chip using a 540 manual non lambda bin file , my Indonesian assembled E34 540 doesn't have lambda
    Anyway, I have a WAR chip coming and I want to correct the AFR curve
    Is these a rule of thumb I can use to increase and decrease fuel flow by reference to the AFR curve and my target AFR ?
