boosted e30 m20 with no spark Megasquirt
    hello everyone.
    new to this page. I have owned several bmws and I just picked up an e30 thats boosted with no spark issue. its running full stand alone on Megasquirt 2. I changed out crank sensor and still nothing. tested the gm board that coils sit on and no power. so I'm assuming its Megasquirt related. any help will be great. I tried to do a test on Megasquirt with spark and still no spark.
    87 E30 325e Boosted
    15 F32 435i
    98 E36 M3
    03 E39 M5
    Did you make the wasted spark setup from the GM coil packs yourself or did you get it that way?
    1989 325i - 2.7i, Holset H1C, 42lb injectors, 14.7 psi, whodwho MS-PNP.
    2009 X5 - DD Duty
    2018 VW Atlas - Wife/kiddie/grocery hauler
      Do you have a JimStim? You should be able to test the spark output with the JimStim. Are you running BIP373's as coil drivers, a quad driver, or something else?
