e85 flex fuel sensor ms2
  • LowR3V'in
    • 4209
    hello i wan't to use the flex sensor so i can run whatever and the afr stays the same has you done it?
    Can ms2 do that?
    Also, could i set a boost map depending on how much ethanol there is in the system?
    i've been out of the ms loop for over 5 years so no idea what it can do now.
    i can do 10psi without det on 91 and basically max out my turbo on e85
    so if it can adjust worry free that would be perfect.
  • citizen_insane
    • Jan 2013
    • 216
    MS2 can set trims for tables based on flex fuel sensors. MS3 can do full map switching.
