Hunting idle with Miller maf installed.
  • Silenpro-ix
    • Sep 2018
    • 2
    Installed new Miller Maf with chip. Everything checks out ok. As soon as you start it the idle goes from 700 to 1500. If I unplug the maf the car idles normal. It’s a gen 3 maf kit. When I checked voltage at idle I have 1.6v at pin 2 on the maf plug. The troubleshooting guide says I should have .8 volts. Now for the gen3 type 1 that’s normal but not for type 2 which is what I have. Could I have the wrong chip ?
  • Silenpro-ix
    • Sep 2018
    • 2
    Icv went bad at the same time. Runs good now.
    • goldenbb
      • Jun 2013
      • 208
      Do you like this setup? My AFM is going bad and I have the basic Miller MAF in a shopping cart ready to hit "order" but haven't done it. I was going to keep the stock injectors and maybe bump the limiter to 6800.
      '90 zinno 325iS
