MSPNP E30/Innovate LC-2 Install
  • E30RoadKing
    • Sep 2015
    • 51
    Hey gang,
    I have the MS-PNP box for my E30, and I'm attempting to install an Innovate LC-2 wideband oxygen sensor. I have the back module with the four wires (red, black, yellow and brown). I have my red wire hooked to the switched 12v pin, the black one to the ground pin, and the yellow wire to the oxygen sensor signal pin, all in the back of the options port on the MSPNP box. my brown wire I have taped off. The issue I'm having is that the LC-2 will not complete it's free air calibration, it endlessly flashes the green lights twice per second, indicating that the sensor is heating up. The manual states this process should take 30-60 seconds, but it kept flashing for roughly 10 minutes before I turned it off. I tried Googling this issue for help, but only found something similar for a first gen Miata, where the OP was told to not use the MSPNP power and ground pins for a wideband, citing that the LC-2 needs 5a 12v and not the 0.5a that the ECU supplies, and that the ECU should never be used for a ground for this. Can someone with experience please advise?
    1969 Chevrolet El Camino - SOLD
    1979 BMW 320i - Traded
    1980 BMW 633CSi - SOLD
    1986 Chevrolet K30 Silverado - SOLD
    1987 BMW 325es - Totaled
    1987 BMW 325ic - Traded
    1990 BMW 325is - First car/Sunday Cruiser
    2004 BMW 325xi - Totaled
    2007 BMW 335i vert - Traded
    2018 Chevrolet Cruze - Totaled
    2019 Subaru Impreza
    1980 Suzuki GS850 - SOLD
    2004 Harley Davidson Softail - Traded
    2007 Suzuki GZ250 - SOLD
    https://www.flickr.com/photos/155574105@N08/albums
  • justinpirie
    • Feb 2014
    • 111
    Originally posted by E30RoadKing
    Hey gang,
    You should have the LC2 on a switched relay, you can use the MS power to control the relay. Power and ground should be from the car, not MS. Innovate say this specifically in their installation instructions. Ask me how I know!
    • citizen_insane
      • Jan 2013
      • 216
      As you found online and Justin mentioned in his post above, you can not power the LC2 from the Megasquirt. The factory harness already has a positive and ground which you can reuse (just chop connector off the original O2 sensor, extend the wires and use it to power the LC2). The factory setup already has a relay in the engine bay for the O2 sensor. Depending on how you have your car hooked up, you can trigger this relay various ways. Mine is setup to trigger when the key is in accessory or run mode.
      • E30RoadKing
        • Sep 2015
        • 51
        Thanks, that's exactly what I did!
        2019 Subaru Impreza
