i need info on MegaSquirt......
  • jay dot dog
    • Jan 2007
    • 32
    i want to get a megasquirt system for my soon to be turbo e30 , but i need some help, what do i need to purchase to get ms to run my fuel and spark, iknow i need a ms unit and wiring harness,,,what about a relay block??? what else do i need to get it up and running????
  • Mr Deagle
    • 1121
    blind faith
    • Mike B.
      • Jan 2006
      • 987
      www.msefi.com - read, read, read!!!
      • grebnut
        • Oct 2006
        • 35
        Are you decent with wiring? Know how relays work? If so, I would reccomend you dont bother with the relay board.
        Otherwise, for spark you will need, depending on how you want to set it up, not much else. Unless, of course, you want to run wastespark or an MSD box, or.... Whatever else.
        The basic stuff, (single coil, 60-2 wheel, fuel, etc.) the regular MS3 can do. Beyond that, you will need more setup and stuff.
        Ben
        • skeides
          • Jun 2005
          • 73
          yea read and read and read..
          you'll need to wire up a relay for fuel pump, Air intake temp, coolant temp sensor and some other things cant think of right now
          • benflynn
            • Feb 2007
            • 30
            ms1 v2.2 will decode the wheel, stock clt sensor should be ok, a open gm iat sensor, must buy a wideband, must, nb o2 is only good to like 4psi, if you can put a dizzy inthere somewhere you can mod it to give the ms phase for the cam and it can do cop 4cyl, ms2 can do cop 6cyl
            9.8:1 2.3l
            msns-e/lc1/evc3
            48mm t3/t4
            3" turbo-tail
            npr
            www.hybridturbosales.com
            • rs4pro3
              • 5808
              the v2.2 board actually doesn't have the wheel decoder circuit only the v3.0 and up boards
              85 325e 2.7 ITB'd stroker
              • benflynn
                • Feb 2007
                • 30
                we have a v2.2 cop 16v volvo in the ATL, just add a little circut, no biggie
                9.8:1 2.3l
                msns-e/lc1/evc3
                48mm t3/t4
                3" turbo-tail
                npr
                • benflynn
                  • Feb 2007
                  • 30
                  9.8:1 2.3l
                  msns-e/lc1/evc3
                  48mm t3/t4
                  3" turbo-tail
                  npr
                  • rs4pro3
                    • 5808
                    ya correct a extra circuit has to be built the way you worded the first post sounded like it was built into the main board.
                    • benflynn
                      • Feb 2007
                      • 30
                      your right, i guess in my head i no longer make the distinction
                      9.8:1 2.3l
                      msns-e/lc1/evc3
                      48mm t3/t4
                      3" turbo-tail
                      npr
