Custom Magnaflow Exhaust Component Questions
  • E turd
    • Dec 2008
    • 102
    Car in question: 1990 325i, manual transmission
    Today was the day my stock exhaust decided to retire. I knew it was coming, but didn't think it would be so soon. While the timing isn't the greatest (just dropped some heavy coin on suspension stuff), it's just as well. A month or so ago I started looking around at what was available, researching, listening to sound clips, watching videos, comparing prices, etc and discovered that the mufflers I liked were priced much higher than I could ever justify.
    After reviewing all of my options, I think I'd like to go the route of a custom Magnaflow setup. The clips I've found with E30's running Magnaflow components seem to have an acceptable level of sound, the pricing is within reason, and the product is readily available. Now, I know trying to get an idea of what a custom setup is going to sound like or how it will perform is rather difficult so I won't ask those questions, but I do have a few you guys might be able to answer from experience or general exhaust knowledge.
    Please forgive me if these questions seem dumb in any way. I usually buy a pre-fabbed system so this is all new to me. Here are the components I am proposing to use:
    -Magnaflow Muffler 14568
    -Magnaflow 36008 Catalytic Converter
    -Magnaflow Muffler 14468 (as a pre muffler/center section to reduce noise)
    Questions:
    1. Catalytic Converter: My current one is toast. It broke up into little pieces and plugged the muffler so it needs to be replaced. Since I live in California, I have to have one and I have to have the one for CA emissions. I had a look on the Magnaflow site and the cat it pulled up for my car had a dual inlet, single outlet. My current cat has dual inlet, dual outlet. The cat I listed above is supposed to be for a 1989 535i and has the dual in, dual out like what I have now. Can anyone see why this wouldn't work or be allowed?
    2. Main Muffler: I read and saw clips of guys from the forums running the 14815, 14816, and the 11378. Aside from the differences in pipe diameter and tips, those three boxes are all quite a bit smaller than the OE unit. Is there a reason people choose these dimensionally smaller boxes to the larger one I have listed above (14568). Though lacking experience, my logic says to try for the closest thing to stock. Are the smaller ones better for sound?
    3. Center Box: This one is a huge unknown for me. The last performance exhaust system I bought was a S/S Jetex for my GTI. It had a resonator, a small muffler, and then a larger muffler. I liked the quiet yet unrestricted qualities it had. However, with the bimmer the engine, configuration, and number of pipes is quite different so following the model of my old Jetex system may not be the way to go. My main reason for wanting a center box or some kind of resonator is to quiet things down as much as possible. I really don't want drone or an exhaust note that tells cops across town I might be headed in their direction. I did a little reading about the difference between a muffler and a resonator, but after visiting the Magnaflow site and seeing what looks like resonators being referred to as mufflers, I've become confused. Also, exactly what sort of resonator do you use for a dual exhaust setup? Do you buy two resonators, one for each pipe? Will adding the center section or resonators restrict the flow too much?
    Priorities for the setup are in this order:
    1. Cost
    2. Subtle-moderate sound qualities (excluding WOT. NO DRONE!!!)
    3. Performance/flow
    Thanks in advance for any help you guys want to throw out there.:D
  • RoDo
    • Nov 2008
    • 104
    Don't know if you are still looking for feedback on this or not but I think your plan is generally sound.
    I went with a custom Magnaflow setup using the 94007 cat (2 inputs to a single 2.5" output) and the 14216 muffler (single 2.5" input and output). The car sounds awesome but it is loud. My understanding is that a larger muffler combined with a resonator would quiet it down. I happen to love how my guy sounds so no further changes are planned.
    The reason I went with a single 2.5" pipe after the cat was for cost reduction. Everyone I talked to/everything I read said that a single 2.5" pipe would flow just fine for a NA M20 motor.
    I think you are going to have to pay close attention on the cat though because as I recall they are listed as 49 state legal, the conspicuously absent one being yours. Have fun!
    1987 325is
    --- used to haves ---
    1988 325is
    1999 540i/6/Sport
    1989 325iX
    1998 M3
    • JRKOUPE
      • Dec 2004
      • 3159
      exhaust...
      I run a header into a mf cat and borla muff.. all 2.5 single.......aggressive but I like it...not obnoxious below 5k....
      • E turd
        • Dec 2008
        • 102
        Thanks for the feedback, guys. After reading that a single 2.5" flows the same if not slightly better than a dual 2" (due to decreased friction, from what I read) I went ahead and had my muffler guy install the following components:
        36037 (CA specific cat converter)
        14416 (Resonator)
        14579 (Muffler)
        The cat is dual 2" in and single 2.5" out. The resonator is single 2.5" in and out and the muffler is single 3" in and out. The conversion from dual to single probably saved me some money during installation and since I don't have any plans for forced induction or really any kind of engine work, the single 2.5" seemed more than adequate. At first I thought it was a little too quiet however, the system has had 3 weeks to break in now and the sound is slightly louder, which IMHO is perfect. Total cost ended up being about six bills and for the most part it looks and sounds stock to the untrained eye.
        As soon as I get a chance I'll post up a photo and sound clip for those discovering this thread down the road.
        • 5ickride
          • 2922
          14416 (Resonator)
          14579 (Muffler)
          Any pics? I'm looking also...thanks
