What to do About O2 sensor?
  • stegosaurus
    • 367
    Searched a good while, and haven't found anything. Please point me in the right direction if I've missed something.
    My muffler had a lot more rust on it than I thought and a stone separated it from the rest of the exhaust. I got a replacement catback section and the cat section fell off in my hand when I was fitting the catback today. The cat is held in place by drywall screws (PO was a champion) and now my car is even more illegal than it was.
    I'm not about to spend money on a cat considering I'll be swapping the motor in the near future (S38 FTMFW) and since I have access to a machine shop it shouldn't be a big deal to make a connector.
    In order to pass inspection I can't have a CEL, and so I'm wondering what people are doing with their 02 sensors in their straight pipe cars. Can I fit a resistor to the sensor? Can I simply fasten the sensor to a frame piece so it can still transmit a signal? Should I try and fit the 02 sensor in the new piece?
    Thanks for any help.
  • sector6
    • 909
    I have a 90ix with no cat. I don't get a CEL. Perhaps your CEL problem is else where?
    • Asbradley21
      • Jun 2008
      • 1938
      I have a 91 m42 with no cat. I don't get a CEL either.
      S54B32 swap in progress. Status: Getting There
      • 416stroker
        • May 2008
        • 2448
        Lawlz have a exhaust shop weld in a new O2 bung.
        A straight pipe wont throw a code on a car with no rear o2 you don't have a obdII
        84 318I Delphin RIP
        87 325IS delphin 24v Sold
        89 325 Alpineweiss
        • stegosaurus
          • 367
          Oh alright then. A friend of mine was telling me that I would have to deal with codes because of a lack of input into the O2. So I can just get rid of it? Will this have any affects on the the air fuel mix?
          • sector6
            • 909
            No, don't get rid of it. It will have some effect on fuel economy.
            • stegosaurus
              • 367
              So it needs to stay on the car, can I zip tie it to a hangar or something?
              • sector6
                • 909
                I don't understand what you asking.
                • stegosaurus
                  • 367
                  I took what you said to mean don't tear the 02 sensor off of the car. In that case I figured I'd have to attach it somewhere since it wouldn't be mounted in the midpipe.
                  Were you saying that I had to keep the 02 sensor in the plugged into the pipe? I guess it wouldn't be too terribly hard to weld the bung into the new pipe.
                  • 416stroker
                    • May 2008
                    • 2448
                    OP your a Fucking Idoit Go to an exaust shop and have them install A new O2 bung in your new mid pipe so you can run your O2 sensor.
                    84 318I Delphin RIP
                    89 325 Alpineweiss
                    • stegosaurus
                      • 367
                      Fucking idoit? Never heard that one before. I've got nothing against taking it to a shop but I know some people run without them and I wanted to know how it worked.
                      Thanks for being a prick, you spelled exhaust wrong too.
                      • 416stroker
                        • May 2008
                        • 2448
                        OK I spelled it wrong. If you dont whant a cell install you 02 its simple. I doubt you can do it your self since you asked this retarded question. So take it to an exhaust shop.
                        84 318I Delphin RIP
                        89 325 Alpineweiss
                        • 5KWattson
                          • Apr 2009
                          • 809
                          damn someones a lil pissy...but kinda have to agree the "zip tie the o2 somewere to the car" thing was a bit retarded
                          "God created turbo lag to give V8's a chance" Taylor D.
                          • drift
                            • 566
                            Stegosaurus, you should consider this :
                            http://www.kingofeurope.net/2010/
                            • 5KWattson
                              • Apr 2009
                              • 809
                              i just cut mine out from between the stock m20 pipes and cut the y pipe on the M50 with my plasma to size and welded it in...but i doubt OP has a plasma nor welder...nor common sense
