Exhaust questions...
    • 37828
    I have some questions for when I put my motor back in the car [stock M20]
    I have an exhaust setup planned out in my head and I am just wondering what you guys think about it. I plan on running single piping for sure and was planning on running my headers, a Y in to 2.5 inch piping, 2 resonators where the stock cat/resonator would be, and then a Magnaflow style single in dual out muffler.
    Is my exhaust piping going to be big enough?
    Other thoughts?
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • bkelsey86
    • 1173
    I think 2.5 will be plenty good you might want to even go 2.25 it just depends. I don't think you'd need much more then 2.5 unless you where going turbo.
    • Rich V
      • Oct 2004
      • 69
      For a "i" motor 2.5" is perfect (especially if mandel bent). It represents about a 5% increase in flow area, not to mention less heat and turbulence due to less surface area. 2.25" would be too small.
        • 37828
        So should I do 2.5 guys? I know more of you have read this.
        Grover Beach, CA
        www.BimmerHeads.com
        • trent
          Yes. Do 2.5.
          • 325is_e30
            • 567
            yes, 2.5 is slightly more flowing than stock dual piping.
              • 37828
              Sounds like a plan then.
              What size si the stock piping on the m20b25 cars? Obviously it's dual compared to me planning to run single.
              Grover Beach, CA
              www.BimmerHeads.com
              • E30godz
                • 1524
                1 and 7/8ths i believe
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  2 x 45mm
                  • screamingbmwe30
                    • Jan 2005
                    • 415
                    is your car running yet?
                    • Budget Beater
                      • Aug 2005
                      • 230
                      2.5" single is best setup with a good y-pipe, ebay has a bunch of cheap 2.5" resonators that will do the job and a magnaflow single in dual out should sound refined but still meaty.
                      • Mot
                        45 toting redneck
                        • 4018
                        would this work? http://cgi.ebay.com/ebaymotors/Unive...spagenameZWDVW
                          • 37828
                          Originally posted by Mot
                          would this work?
                          That could work. I ended up putting a glasspack in my center section, no cat. Sounded really good
                          That exhaust has been sold though
                          Grover Beach, CA
                          www.BimmerHeads.com
