Building custom exhaust
  • alpinee30m50
    • 647
    Im ordering supplies for my exhaust soon, im already set on my muffler and resonator but im not positive as to how much tubing to get. Im thinking two 4 foot sections of 2 1/2 inch pipe, and 3 180 degree mandrel bends all from summit racing. Anything else i should order to make the exhaust? Flex fittings or anything like that? Note: This is all being welded and installed by me and my buddies.
    Thanks,
    Jesse
    86 Zinno es
    M50 inside
  • 619E30
    • 1753
    I think you might need more than 4 feet of tubing
    Originally posted by audiquattrot
    bimmers b4 b*tches....remember that.
    1990 Alpinweiss 325i - secret 500whp build
    2000 Audi S4 B5 Laser Red
    1990 Nissan 240sx - Drift Missile
    2006 CBR600RR
    • alpinee30m50
      • 647
      Im getting 2 4 foot sections of straight tubing
      86 Zinno es
      M50 inside
      • rpob5t
        • Aug 2007
        • 162
        depends on how you're going to do it, I built mine with 2 45's and 1 180 with some left over (I also ran a resonator and muffler in line) granted I built a short system with track use in mind but 2 extra 45's would have done the trick to tuck a muffler up after the SF:
        http://farm3.static.flickr.com/2614/...f79bc7bf_b.jpg
        http://farm3.static.flickr.com/2688/...b77240f6_b.jpg
        Just a note the 45's are a little easier to weld up vs' the 180 as no mater how good the mandrel bend is the pipe will oval a little during the bend; where the 45's will give you two round ends to weld together. Its not a major issue just might have to "round out" the pipe in a bench vise so everything lines up cleanly
        Greg 1987 325is (fairly far from stock at this point)
        • ChaseN
          • 709
          I ordered 5x 45* mandrel bends, 2x 4' straight sections, and used two magnaflow mufflers in my system. You may want a flex joint at some point in the exhaust...on the s50b32, one of the headers has one built in, so I didn't have to worry about it.
          By the time I was done, I had a ludicrous amount of pipe left over.
          1991 318iS
          1992 911
          2006 330i 6-Spd ZSP people hauler
          Gone:
          1989 M3 S50B32, 6-Spd
          1990 325ix 5-Spd
