Can't find them to order, i need the bolts that connect the manifold to the block, I found the part number on realoem, but nobody seems to carry them.
Exhaust manifold bolts
Tags: None
The easiest thing to do is go on ebay or where ever you found them figure out what size they are, and the thread pitch. Then to your local hardware store and buy some grade 8 bolts with lock washers to. Make sure to put anti seize on those threads other wise if you don't when you take it apart for what ever reason you won't be able to do so cus they will be seized on to the head.sigpic
85 swartz/metallic 325E
84 alpine 325E
85 zinnoberot 318i/R.I.P
84 Bronzit 318i/sold
purchase feed back here=http://www.r3vlimited.com/board/show...82#post3535282
