Chopping Off Catalytic Converter
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    I've always done this with my older Cadillacs but this is my first BMW so I wanted to make sure that getting my cat chopped off isn't going to screw with the engine or computer. Will the engine run fine without it or does it have any sensors that the ECU reads from?
    • 37833
    It will run just fine without it
    Grover Beach, California
    BimmerHeads.com
    • RobertK
      • Jun 2005
      • 5864
      Wooohoooo!
      • uflnuceng
        • Apr 2005
        • 1049
        Yeah... I did that and had excellent results (mostly from weight loss).
        Just make sure you put a resonator of some kind there or things will sound funky. They are already going to sound LOUD. Going under bridges was awesome :twisted:
          • 37833
          If he's still running stock muffler with no cat it would be alright but ya, if it's an aftermarket muffler and no cat, you'll need something there
          BimmerHeads.com
          • RobertK
            • Jun 2005
            • 5864
            Would a glass pack work ok as a substitute for the cat?
            I do plan on having a custom dual exhaust installed.. should I keep both pipes seperated and have two cat substitutes?
            • uflnuceng
              • Apr 2005
              • 1049
              As a resonator, maybe. As a catalytic converter.. no.
              Your preference. Some stay 2-into-2, some go 1-into-1.
              • RobertK
                • Jun 2005
                • 5864
                Not too worried about the Catalytic Converter functionality of a glass pack because there is no emission testing where I live. If it will work as a resonator then everything should be good.
                • uflnuceng
                  • Apr 2005
                  • 1049
                  DO a search on galsspack in this forum. I think someone says they did just that (replace cat with glass pack for resonator effect).
                  Good luck with it.
                  • rs4pro3
                    • 5808
                    Just a warning, Chattanooga started Emission testing last year, and I've heard either Knoxville or Nashville will be the next city to implement it. They do a visual inspection to make sure a Cat is in place. So you may want to check with the DMV to see when and if Knoxville will be starting it.
                    85 325e 2.7 ITB'd stroker
                      • 37833
                      On my old custom exhaust I had a glasspack where the cat would be
                      BimmerHeads.com
                      • Skafrog
                        • 1732
                        Nashville and the immediate surrounding counties have been doing emission testing for the past ~10 years. Knox county is wide open, however. Those bastards.
                        NASA MidSouth TT Director / GTS2 #018
                        Mods: Coastal PS Fluid, 10w40 Oil
                        Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                        • rs4pro3
                          • 5808
                          I had heard it was going to go into place in all of TN, I'd still call the DMV in Knoxville to see as no point spending a lot of money on exhuast if you'll have to do it all over again in a year.
                          • JRKOUPE
                            • Dec 2004
                            • 3159
                            I tracked my car over weekend and there was another e 30 w/ a 2.5i and straight pipes( no converter)....he had 2 pipes running into one into a glass pack........it sounds like a race car( it was)...... way too loud for street.....perhaps if you add another gp........
                            • RobertK
                              • Jun 2005
                              • 5864
                              Emission testing was already voted down a couple months ago.
                              As it is now Nashville is only requiring emission testing on large trucks, vans, and SUVs.
                              My current idea is to run 2 seperate pipes and have 2 GPs in place of the cat (1 for each pipe) and then 2 seperate Borla or Magnaflow mufflers.
