Hey Folks. So failed CA smog and am looking into getting a catalytic converter to fix it. What are my options? Is it worth a trip to pick and pull to grab a cat? Or is the used cat going to fail too? Do I have to buy OEM cat? If yes how much does that bad boy cost? Is there aftermarket stuff? Essentially what are my options and how much are we looking here?
Catalytic Converter Options
Life is too short to be driving a Honda.
sigpicTags: None -
Not sure about out your way, but here they cut the cats off all cars that come into the salvage yard. I am sure there is a legitimate reason but I have no clue what that is. I recall seeing cats available on ebay for less than the cost of OEM but that's been a while.
Quick google search:
I can't get a cat from the pick and pull, they take out the cat before they let the public rape the cars.
I believe / guess you can buy a universal cat for about 80 or something, even though it says its not CA legal it will most probably pass. I have a universal cat and i passed. OR it could be your o2 sensor that is giving bad readings.Comment
A California approved (aftermarket brand, not oem) cat is going to expensive, over $400 iirc. Your better off getting a universal cat. As long as it passes the sniffer, you should be fine. I doubt most smog places are going to look too closely at the cat. If you really want to save money, buy a used oem cat from the classifieds, but you run the risk of it being bad. I bought a CA approved cat, but I probably wouldn't do it again.sigpic
January 2012 COTMComment
As some others have said you most likely will not be able to get one from the local junkyards. Not sure about in CA but in MD it is illegal for the yard to sell you a cat.
A local muffler shop should be able to weld a new one in for you for not too bad.
If you have the $ and want an easy bolt on setup Turner has a bunch for every model of E30 - http://www.turnermotorsport.com/BMW-...onverters.aspx
Bimmerworld has the same for possibly a bit less - http://store.bimmerworld.com/dec-cat...ies-p1103.aspxComment
In california it is illegal for yards to sell used cats. they are required to remove them from all cars.
I failed smog earlier this year in cali, got a new cat and was waaaaay cleaner then the average #'s.
my smog guy got me hooked up really good, brand new, CA approved OEM cat, and install for 275$. cheapest ive seen anywhere.....Comment
my smog guy got me hooked up really good, brand new, CA approved OEM cat, and install for 275$. cheapest ive seen anywhere.....-----------------------------------
sigpicComment
Go on craigslist, find wrecked e30, get cat for cheap, pass smog, sell on r3v... profit?Jah bless! :pimp:Comment
I have a magnaflow cat with twin inlet outlets I could sell you. Id let it go for cheap its just colecting dust. Though youd most likely have to get some new exhaust to make it work.sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713Comment
We need to all chip in a few dollars and send a cat around like hans, only to be used during smogging lol.Jah bless! :pimp:Comment
Something else that needs to be noted is that it is now illegal for a business within the state of California to sell you (a CA citizen) a Non-California approved muffler.Comment
That's a sweet ass idea. At least us southern california folks could start this and pass it around. there seems to be enough of us to get this idea to materialize.-----------------------------------
sigpicComment
plenty of places online to buy
you might like this site http://www.californialegalconverters.com
at the least, it might answer your questions
good luck....it's confusing in CaliComment
'92 BMW 325ic 2.5L CA CARB approved, Magnaflow universal high flow dual in/dual out #36008 $186.45 to your door. Hottexhaust.com 800-288-7730. That part # is not listed on line, must call. to discuss.
Are you sure it is your cat? Can you post a cc of your smog readout? Was it good & hot when you tested it? Do you have any vacuum leaks? How long did the car sit before you bought it? A simple search will bring up a number of instances where a simple tune-up & fixing any engine air leaks (cracked air intake elbow?) got many cars to pass. Getting it to run good can clean-up tail pipe emissions.Last edited by cactusjacks1; 09-21-2011, 01:37 PM.[IComment
