Oxygen sensor placement?
  • 88SuperETABD
    • Apr 2009
    • 911
    So I know the o2 sensor needs to be added before the cat, and between 10 and 2 oclock up top, but here's my question and I searched but failed to find an answer,
    So for these headers, for my m20
    They come with a bung, but there is 2 collectors, and one o2 sensor...is it best to have an x pipe and drill the bung into that x so it reads from all 6 cyllinders(How BMW did it) rather than 3. I contacted topspeed and waiting for them to get back to me with the answer, if its okay to just do it in one collector, which do i put it in? Front or back 3 cylinders? Does it matter?
    I'll be piecing together my exhaust, got Scorpion Oval catback coming in the mai,re using my high flow magnaflow cat (lessthan 5k miles), and these headers.
    (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
    1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
  • Grant318is
    • Feb 2012
    • 291
    IMO, I would stick with the factory design.
    MY BUILD: The Grant318is Build
      On an M20, the O2 sensor must be where it sees the flow from all six cylinders, just like where it is in the OE down tubes.
      • 88SuperETABD
        • Apr 2009
        • 911
        I'm thinking I should cut off the stock one and re-use it.
        Is it supposed to be as close to the headers as possible?
        • tonerrrr
          • Jul 2011
          • 935
          I'm not sure about your setup but here is where mine is for my 86e:
          instagram: @tonerrrr
          High resolution E30 Fuse Box 300dpi PNG
          • 88SuperETABD
            • Apr 2009
            • 911
            thats not the stock location is it? Seams far back, mine originally was able to be taken off from under the hood. I didnt have to crawl underneath.
            • george graves
              • 19997
              I don't think this is true. Ideally yes, you'd have a small crossover pipe. But I've been running my m30 on one bank of cylinders for years and it runs great. How do I know? Cause I have a wideband on the other downpipe.
              Too far away and it won't get the heat it needs IIRC.
              Originally posted by Matt-B
