Options for exhaust
  • JA1991
    • 452
    Options for exhaust
    I had a 3in exhaust made for me by blueapplesoda and since i've put my coilovers on it scrapes on just about everything. Obviously Michigan doesn't have the best roads but i feel as if my exhaust hangs abnormally low. I like it a lot, it sounds good, i'm also going to be turboing my car over the winter so a 3in is what i'm looking for. What could i do to help my exhaust not scrape as bad without raising my car. It scrapes the worst in the rear around the axle portion. I don't really want to cut it apart but i'm thinking an oval pipe might be my only option??
    I'm going to get pics tomorrow of how it sits.
  • duleymane///iS
    • Jun 2012
    • 153
    That looks awesome, cant give you any advice on the tucking of it as i drive a 4x4 status e30, just wanted to know if you think its loud i have the same set up only i have 2.5 to 3in and that same muffler. Mine is really loud i dont like it.. GL with the scraping issue
    • DetailAddict
      • Apr 2011
      • 245
      where is it scrapping?
      • JA1991
        • 452
        The Vband keep hitting the ground, but the exhaust is already sitting up as far as possible. So unless i weld it into one solid piece then i dont know
        • Vivek
          attention whore/retard/bitch
          • 6167
          Mounted pics would help. If it's already mounted up as high as it can go...that's about all you can do.
          1992 Mauritiusblau Vert
          2011 Alpinweiss 335is coupe
          2002 540i/6 Black/Black
          2003 GSX-R 750 (RIP)
          • JA1991
            • 452
            i'll try to get some, where the vband about 1/3 of the way back is keeps getting broken, i haven't even lowered the front of my car yet, the back tucks tires, the front has like 2inches of wheel gap haha. i might make a smaller exhaust, but i plan on slapping a turbo onto it this winter so idk
            • DetailAddict
              • Apr 2011
              • 245
              is it around the transmission mount? If I remember correctly, there isn't a lot of space there, but if you move it back a bit, where the cat/resonator used to be, you should have more space.
              Leo
