Catalytic converter flange replacement?
  • ksjdan
    • Jul 2012
    • 330
    Hi all,
    I am currently in a process of replacing the muffler and all exhaust gaskets. When I was removing the catalytic converter, I noticed both of the flanges were badly rusted, and one of the flange actually has a crack spot. I got the entire exhaust off and took a photo of it.
    I checked bmwfans but noticed there is a part number for only one of the two flanges. Is there a way I can replace the flange that is "trapped" inside the pipe?
    My 1990 325is Build Thread
  • jrobie79
    • Mar 2006
    • 2525
    what I did for mine, was find one similarly sized from an auto parts store, then I cut it in half with a cutoff wheel, chamfered the edges that matched up, put two halves together behind the flanged, then welded it back together....its been holding for 3 years now
    1991 318i ---- 308K - retired
    • SmokeE30
      • 1730
      i have some old exhaust laying around with flanges if u wanted to cut and weld
      Shawn @ Bimmerbuddies
      Bimmerbuddies LLC
      717-388-1256
      2971a Roundtop Rd, Middletown PA 17057
      bimmerbuddiesllc@gmail.com
      • DetailAddict
        • Apr 2011
        • 245
        +1 on cut and weld
        • ksjdan
          • Jul 2012
          • 330
          Thanks for the input guys. I dont have much knowledge in welding, nor have the tools to do it. So I just dropped it off at a exhaust shop today and Im going to get him a few flanges to work with. He's going to cut the pipe, insert a new flange and weld the pipe back in place. It seems like a bigger mess than welding the flange. Thoughts?
          • DetailAddict
            • Apr 2011
            • 245
            well, it depends on how good they weld and what kind of flanges they'll be using. if you want to say compatible with other oem pieces, i would replace the broken flange. if not, hope their weld is good and keep the exhaust in alignment when done.
            • ksjdan
              • Jul 2012
              • 330
              He has a decent reputation so I think he can handle a simple job like this. I'm going to give him a few oem flanges. He's charging around $60.
              • ksjdan
                • Jul 2012
                • 330
                In case anyone was wondering, I got the catalytic converter back from the welder. It looks better than I have anticipated.
                Here is the result. He cut the neck of the pipe off, and rewelded from the inside. Looks almost like the way I gave it to him...but with a new flange on it.
