I am using a Mani adapter off a guy here but in the pics look closely. One part is literally on the pass side frame rail, and also the wg is millimeters above the manifold. However the oil drain/ic piping/down pipe seem clear, feed line might be tight. Should I be ok wrapping the manifold and adapter with exhaust wrap?
I just do not want the wg exposed to excessive heat or have an issue with iy touching the frame.
I have no issue banging in the frame rail if possible or rewelding and retorting the wastegate possibly to weld a 90* up and have the wastegate sit between 3 and 4 cylinders
