Oval exhaust
  • Vtec?lol
    • Dec 2009
    • 3278
    Oval exhaust
    I'm trying to put pieces together for a stainless exhaust on my m60 build.
    I saw some oval tubing and was wondering if anyone used it?
    Going to be picking up a hobart EZtig and some argon to get it done with and hopefully can resell when I'm done with it.
    I'll be using v-clamps all around
    2.5 from mani to the cats
    cats to an x-pipe
    then duals to a Y for a 3 outlet-tip OR dual pipes to a 2-1 muffler for a 3 tip?
  • IronFreak
    • Dec 2012
    • 3702
    Talk to Eurotrash, he used it on his 5.0 swap. seemed to work well besides the price haha.
    Instagram @rebellionforge
    • deutschman
      • May 2008
      • 5958
      Only resin I see to use it is ether because you are slammed flush with the road, or you need to have a flat bottom car for under car airo.
      Vibrant seams to have a good selection of round to oval transitions and oval tube and bends if your going that rout.
      • Rc 415
        • Jun 2011
        • 723
        I used it. You want to try and run a dual setup with the oval exhaust?
        1987 Delphin 325IS
        LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
        Build Thread
        1993 alpine 2 325IC
        •Ground control coilovers•16" BBS RS• momo woodgrain
        • Vtec?lol
          • Dec 2009
          • 3278
          I'm trying to staly as flush to the bottom as possible. It's going on a cabby.
          I'm trying to do duals to a single at the end because my cabby is a 318i so the valance has a single round exhaust cut.
