how to mount magnaflow on Eta with 2 pipes
  • z6ne
    • Dec 2012
    • 758
    Reposting this from exhaust subforum:
    So I have an 86 Eta, and it has dual pipes coming from headers into the stock muffler. I don't know if this is stock or not because I also think the cat has been deleted.
    I'm looking into a used magnaflow for a fair price, and have a few questions on mounting it. This muffler has only a single inlet pipe, waiting on more info for it (part number and diameter of inlet pipe).
    My questions are these:
    Are the dual pipes on an Eta stock? The PO did a bunch of wierd shit to the car so I wouldn't be surprised if they are not stock.
    Is it advisable to use a Y pipe to divert the 2 pipes into 1 pipe, then to muffler inlet? Is there a desirable place to do this to minimize any loss in airflow? (right in front of muffler VS back further towards headers?)
    My county does not require emissions testing on a car of this age, so are there any positives/negatives of leaving the Cat. off? Should I get a resonator? Does this only affect sound or does it have other effects?
    sorry for all the noob questions, I searched a lot on multiple forums and could only come up with so much. thanks for any advice
  • Vivek
    attention whore/retard/bitch
    • 6167
    Nope, it looks like he switched a full I exhaust from the manifolds back. On an eta it merges into 1 and goes 2 manifolds->down pipe (single outlet)->cat->resonator (I think)->muffler. it's basically the same on a stock 325i except it's dual pipes the whole way through.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • z6ne
      • Dec 2012
      • 758
      so how far back should I put the Y pipe on there? Or is that not a good option?
      • Vivek
        • 6167
        It depends on the diameter of the inlet to the muffler (if it's too small you should consider a different muffler since it could cause a bit too much back pressure). I'm no exhaust designer and I don't know the physics of how the gases flow, so I can't comment on the ideal place for where it should go, but I'd assume as close to the muffler as possible would be logical.
        • z6ne
          • Dec 2012
          • 758
          thanks for the input. Are there any people on here that are skilled in exhaust setups?
          Dude's only asking $35 for a magnaflow used a couple times and taken off. I'm yet to get a part # from him but I'm poor and building my car bit by bit, so every deal helps.
          • F34R
            sLaughter
            • 12385
            If it is a magnaflow I would snag it for 35.
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
            • z6ne
              • Dec 2012
              • 758
              Yeah I figured I would. Even if it doesnt end up working on my car (without expensive mods) I can at least sell it and make a bit of profit. He said it was only 65 new though, so I really just wanna figure out the model number to see what's up with it, maybe he just got a good discount.
              • CabbE30
                • Aug 2009
                • 2358
                The magnaflow is only going to give you sound over your current set up. The performance of the "i" exhaust is about maxed out already for the M20.
                • F34R
                  sLaughter
                  • 12385
                  i exhaust adds 19hp, known fact ;)
                  Current cars:
                  ~ '87 535
                  ~ '06 X5 4.8is
                  • z6ne
                    • Dec 2012
                    • 758
                    yeah I hear ebay chips add 35 :mrgreen:
                    • z6ne
                      • Dec 2012
                      • 758
                      any tips on mounting it?
                      • z6ne
                        • Dec 2012
                        • 758
                        ttt
                        • F34R
                          sLaughter
                          • 12385
                          Weld it on.
                          Current cars:
                          ~ '87 535
                          ~ '06 X5 4.8is
                          • z6ne
                            • Dec 2012
                            • 758
                            Weld it on.
                            :zzz:
                            specifically the placement of the Y pipe
