Cat converter
  • Jbpka06
    • Feb 2006
    • 551
    Cat converter
    My exhaust is rusted out and I will need to replace it. I was figuring just to go the cheap route and do magnaflow, sound doesnt really matter too much. What are my options for a catalytic converter, dual/dual? Im planning on just getting custom pipes from the cat back. Should i do 2.25" single to a single/dual muffler or keep the dual exhaust? Any input is appreciated I'm really confused.
    Jesse
  • Scott314
    • Jan 2005
    • 287
    The OEM Eiberspacher exhaust is good quality, and not that expensive. If you want to go to a single pipe setup, go for a 2.5" with a Y-pipe just behind the downpipes. If you're planning on staying with dual pipes and want to replace the OEM cat, those things are an arm and a leg new.
    My fast says: traction control is for the faint of heart :evil:
    • Jbpka06
      • Feb 2006
      • 551
      should i just get something like this, and does anyone know where i can get one for cheaper than $80 on justmagnaflow.com
      There is also one of these.
      I just want a cheap exhaust so i will pass inspection.
      If i get a y-pipe welded in after the downpipes and run a single 2.5" that should be good right. That seems much cheaper because single/single cats are much cheaper.
      • bimmers4life
        • 420
        ebay
        • Jbpka06
          • Feb 2006
          • 551
          should i just do a y-pipe with a cheapo 2.5" catco then pipes back to a 2.5" in/dual 2" out. does that sound like a setup that will work without alot of problems?
          • Budget Beater
            • Aug 2005
            • 230
            do a full 2.5" system, catco cat is $37 on ebay brand new and is same to magnaflows carsound cat. it also improves sound as well as performance. I replaced my full system with 2.5" system (look at my budget beater link below). hope that helps
            • Jbpka06
              • Feb 2006
              • 551
              I like what you did, but how much was the y-pipe you welded in cost? because the magnaflow cat will weld right up with 2 reducers. Im open to anything, i just want to keep it cheap, i can get the labor for free. Whats the stock pipe size on a 325i?
              • Jordan
                • 12913
                Something alot of people don't seem to understand about cats:
                The major catalyst in them is Platinum.
                Look up the price of Platinum per OZ.
                Now apply your new found knowledge.
                Factory cats have a high amount of Platinum, last just about forever, and are VERY good at being a catalyst.
                Cheapo after market cats... well... did you learn anything?
                https://mtechniqueabs.com/
                • Insanity
                  • Jan 2006
                  • 135
                  Another fun fact about catalytic converters:
                  Keep your engine in good shape, and you won't need a functional one to pass smog.
                  • Jbpka06
                    • Feb 2006
                    • 551
                    Well theres a big ass rusted hole in the heatshield of my cat with insulation hanging out and more rust under that. What do u do then?
                    • Insanity
                      • Jan 2006
                      • 135
                      take off the heat shield
                      • Jbpka06
                        • Feb 2006
                        • 551
                        The cat under the hole has rust on it too, wont that eventually rust out too?
                        • Insanity
                          • Jan 2006
                          • 135
                          Most likely. but you'll definitely hear it when it does.
