Help with horrible exhaust note
  • ruqknuf
    • Jul 2009
    • 378
    Finally got around to installing my new exhaust set up. (cat removed)
    Bav Auto headers -> mid pipes -> Y adapter -> single 2" run to a single 2" inlet Supersprint exhaust -> dual tips out.
    HORRIBLE raspy exhaust at initial take off and between shifts.
    What did I do wrong?
    I'm really wishing I hadn't fucked with removing the cat.
    Add an X-Pipe ? Resonator ?
    Any help appreciated
    Leave Feedback here:
    http://www.r3vlimited.com/board/showthread.php?t=261541
  • Mthrizzle
    • Oct 2007
    • 390
    You might want to put a resonator in or a free flow cat...my set up used a universal cat and it toned it down a bit..sweet idle..crowls at higher rpms
    • ruqknuf
      • Jul 2009
      • 378
      So . . . a resonator or hi flow cat tied into each straight pipe ?
      • straight6pwr
        • Sep 2004
        • 3450
        cats would be pretty pointless unless you have to meet emissions requirements or care about the environment. i'd stick a pair of resonators right before that y-pipe. looks like the only place to fit them without redoing your piping. ideally, i would think moving that y-pipe to the straight section right after the headers would let you run just one longer/bigger resonator on the 2" single section right under the driveshaft.
        • AndrewBird
          The Mad Scientist
          • 11898
          ^^^That's what I would do. Having the headers merge closer up to the engine is better as well. You don't need an x pipe if you have the Y there as it is essentially one.
          • ruqknuf
            • Jul 2009
            • 378
            So headers directly into the Y ? ? -- or should I allow for a few inches of that 2" straight pipe before tying in?
            Also - any advise on the length/brand of resonator ?
            Thanks guys
            • greentalks43
              • Nov 2011
              • 39
              I would suggest merging the headers into the y-pipe and running a single pipe into straight through muffler and finally to the supersprint. I did a similar setup and the sound is fantastic. OEM header -> high flow cat -> borla xr1 -> full boar and its quiet at idle and really opens up when you step on it. Prior to that set up I had the y-pipe merged at the rear axle like your current setup and the exhaust was horrible with an unbearable drone...
              • 3vilE30
                • Jan 2013
                • 344
                Contact Digger
                or put a 3in out y-pipe right where the headers end and run 3in piping all the way back with a resonator and a muffler.
                You need a resonator tho it'll help ALOT.
                • ak-
                  • 12422
                  Screw resonators. They don't make all that of a difference.
                  Move your Y-pipe closer to the headers, and get a second muffler put in in that gaping space where your current Y-pipe is.
                  Doing this is also going to get you the proper o2 reading from all cylinders instead of just 3 from where I can see where your bung is now.
                  Maybe have them put a V-band after the Y-pipe and another before the muffler to make life easier when you need to service things.
                  1991 325iS turbo
                  • ruqknuf
                    • Jul 2009
                    • 378
                    Thanks for all the input !!
                    I'll keep you posted
                    • ruqknuf
                      • Jul 2009
                      • 378
                      RASPY note gone.
                      Exhaust complete:
                      Bav Auto headers -> Y adapter(single 2.5" outlet) -> Vibrant Resonator ->single 2.5" run into a single inlet Supersprint exhaust -> dual tip out.
                      Bung now located just after the Y in the single 2.5" run.
