Twin inlet cat-back options...
    Trying to explore what my options are for a twin inlet/outlet cat-back exhaust, or simply a muffler w/ tips. Haven't found much, short of just dumping $400+ into a entire cat-back system.
    Wondering if you fellows might know of something, wish Magnaflow had a twin inlet option, as there's all seem to be single inlet.
    Thanks in advance,
    Trevor Ely
    '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
    '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
    There aren't many 2 inlet/outlet cats out there cheap. You could just use 2 small-body cats with single inlet/outlet.
    Key ingredient is a good muffler shop, unless you just buy a whole system and bolt it together.
    Bret.
      Bret.
      Yeah, I've got a pretty dependable muffler shop...just trying to avoid buying a whole cat-back, but my options are slim.
      Guess I could use two glasspacks.
      Trevor Ely
        DOH.
        Just re-read the original post- you didn't mention replacing cats......so much for my reading comprehension.
        Anyway, the dual glasspacks are cheap and easy. I did mine about 8 years ago, they are pretty much completely hollow now- all of the packing has blown out, but they sound pretty good.
        Just cut off the old muffler and weld on 2 glasspacks, fab up a hanger and go!!
        Bret
          DOH.
          Bret
          Well, actually I'm doing a twin exit header, fabbing the midsection...just trying to find a muffler w/ tips or cat-back to cut up and finish it all off.
          Trevor Ely
