I've done some intake work on my m20 and now think it's time to free up the exhaust with some headers. Can anyone explain what is the difference between long and short tube headers? Thanks
long vs. short tube headers on E30 M20b25
Anyone wanna chime in? I say go long tube. All real headers that actually do something are always long tube. -
something about exhaust gas velocityYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
trent
Shorty headers just increase the size of your exhaust at the ports, and make the flow from 6-3-1 smoother than it is with the stock manifold. Long tube headers 'tune' your exhaust pulses so that there is a certain (high) rpm at which the pulses are timed to pull each other along, increasing velocity, upping hp. Of course, headers in general are more beneficial if the rest of your air-system (intake, cam) is already taken care of.
Someone correct me if I'm wrong.
Edit: Oh, and I believe Trent means "neither are worthwhile mods". Depending on how much money you have to throw around, he could very well be right.This is your M20 on steroids:Comment
Thanks Mr.K. I've got a big bore throttle body, M50 injectors and I'm looking for the 027 M30 airflow. I was thinking I would benefit from some exhaust work. I'm trying to weigh the cost benefit of shortys vs. long and any performance gains. My thought was that at a minimum the shortys had to be better than the stock mani and not too expensive.Comment
how much for that Maf kit you speak of?Originally posted by ebelementsAlso, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.Comment
the split second is upwards of 700Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
A quick explanation of headers: Properly designed headers use exhaust pulses to create a vacuum behind each pulse. The "tuning" of these means that each wave is properly spaced to create maximum suction at the RPM you are running.
Longer tubes are tuned for lower RPM (lower resonant frequency) thus are more appropriate for street.
Basically, the "long tube" types are still not long enough for 2500~3500 RPM that are typical cruising speeds, so will make more of a difference above 4500 RPM.
Placement of the "X" or "Y" makes a huge difference too.
The shorties are so short that there will likely be a big loss of low end torque, but much better power above 7500 RPM...not too helpful on the street.
LukeComment
I've got a 2.7l beast of an eta engine, 283 cam, 325i intake stuff, m30 afm, markd chip, etc. I just installed Bavauto Longtube headers (y-piped to single 2.5in all the way back) and noticed quite a difference. It used to start really pulling at ~3500rpm all the way up, but now it starts around 2500rpm, and even harder at 3500rpm, all the way to 6500rpm (where the small valves limit air flow). I noticed a definate difference. I'd get these headers again in an instant, and they were definately worth the $600 price tag.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
