custom questions
  • ctownhawk
    • Sep 2006
    • 121
    custom questions
    there is a local shop that two of my friends have went to for their custom exhaust setup. I was wondering if there are any popular setups. i tried checking out e30tech, but it seems all they talk about are 3 inch pipes for turbo'd motors.
    i plan on getting longtube headers later on, so i guess i have to get the exhaust put on along with the headers, otherwise they wont fit; correct?
    do i have this right? headers> dual 2.5inch pipes to a dual 2.5in to 3.0out Y pipe to the cat. then a 3.0 to 2.5 y pipe out to dual 2.5in pipes until it hits the muffler. finishing up with dual 2.5 tips?
    i dont remember who had them, but someone on this forum had dual 2.25 curved chrome tips on his and i liked the way they look; although i'de probably want them a little bigger. anyone know which im talking about?
    • 37833
    Dual 2.5" is WAY too big. Single 2.5 is perfect for a N/A M20.
    Grover Beach, California
    BimmerHeads.com
    • AndrewBird
      The Mad Scientist
      • 11898
      I'd go dual 2.25". You can't really have to big of an exhaust (until you get get REALLY big anyway), but there is a point where larger isn't any better.
      A stock i is what, dual 2.25" all the way back? Or smaller?
      • matt
        • 3732
        MUCH smaller. 1.75ish. And yes, you CAN have too big. Single 2.5 is pushing too big for a stock M20. Big enough that you'll lose more torque than you gain HP.
        The irony is that this will make the car feel faster, because it will make the HP and torque curves steeper.
        Single 2.5 is perfect (a little too big) for any motor up to 300hp. Seriously.
        /rant
        • ctownhawk
          • Sep 2006
          • 121
          okay so i make the pipes the same size, if not .25? bigger than the stock ones? how about the size of the tips?
          • matt
            • 3732
            I would do one pipe. 2.25 all the way back with a highflow cat, resonator, and muffler. Then put whatever tips you want on that. Most magnaflow tips are 2.25 inlet anyway.
            • drifty340i
              • Oct 2004
              • 1076
              Yip a 2.25 will be heaps, 2.5 will support 350hp without restriction. my 4.0l v8 e30 runs a single 2.5
              sigpic340hp V8 e30 FINISHED!!!!!
              Quick vid for ya ;) http://www.youtube.com/watch?v=vp5Eaf8xOgM
              NEW One on the track :)
              http://www.youtube.com/watch?v=K-AX5SzSLnk
              Cleaning up some 911s and Jap turbos
              http://www.youtube.com/watch?v=Ad79wsLdle4
                • 37833
                Unless you're boosting, then 3" it is. :)
                BimmerHeads.com
                  • 37833
                  I would never run tiny single 2.5 exhaust on a V8.
                  BimmerHeads.com
                  • matt
                    • 3732
                    Well, with a turbo motor the only downside to the larger pipe is weight and routing problems. An NA motor will actually lose torque if you use too big a pipe. But yes, with a turbo bigger is always better. Of course there's still a point of diminishing returns.
                    • ctownhawk
                      • Sep 2006
                      • 121
                      whats the benefit of a single 2.25 vs dual pipes of a smaller diameter?
                      • matt
                        • 3732
                        Dual has better ground clearance and better sound control.
                        Single is lighter.
                        • drifty340i
                          • Oct 2004
                          • 1076
                          Trust me its heaps on a 300hp ish small 4.0l v8 mate, we have done ALOT of research and talked to all the experts. We have done tests on the 4l v8 in question and all of them lose tq, low and middle range hp with the 3inch pipe. only making it up in the high range, with no advanages over a good mandrel bent 2.5 inch zorst. It sounded crazy to me at the start to, i though a 3inch would be the go, was actually quite worried the 2.5 would cause restriction. how wrong was i lol
                          • silversleeper
                            • Mar 2005
                            • 2032
                            i would think that the ideal N/A setup for our cars would be either SINGLE 2.25" or DUAL 2".
                            As for best sound, I have not the slightest clue. I really am interested in running a custom dual exhaust with an x-pipe.
                            Claus Luthe is my hero.
