guys running no cat...
  • JAM
    • Feb 2007
    • 524
    how loud is your car? im consitering cutting the cat off of my car and replacing it with a straight through exhaust. would it be stupid loud?
    fyi, bmw e30 cats go for about $140 at the scrap yard :D
    Originally posted by Mr Watsonsilver
    driving boards?
    • 37829
    I have no cat but I do have a muffler in the center section so that makes up for it.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • dlmpsy
      • Sep 2006
      • 189
      I don't have cats on my car, and I have a Bosal muffler (with holes) which will soon be replaced with a Stromung muffler. Loud is a relative term, but it doesn't really bother me. I am use to V-8's with Flowmasters.
      • silversleeper
        • Mar 2005
        • 2032
        the only downside i saw after removing the cats from my 325i with the IE stainless catback, was the rasp.
        but i recently found out that companies make rasp eliminators now.
        Claus Luthe is my hero.
        • JAM
          • Feb 2007
          • 524
          word, thanks for the input guys, some kid on a local board is giving away a tt stainless 2.5 catback with a flowmaster for a passat... tiem to do some cutting and welding :)
          driving boards?
            • 37829
            Maybe I understood you wrong but if you bought an IE catback you still have the stock cat.
            Grover Beach, CA
            www.BimmerHeads.com
            • silversleeper
              • Mar 2005
              • 2032
              Yes, thus the term "cat-back".
              But when I had it installed, I removed the cats to get more sound out of the system, which it did. But with the addition of rasp. E46 M3 rasp. It's not bad sounding, it's different, but I prefer a deeper, cleaner sound.
                • 37829
                Ah, gotcha.
                You could always add a center muffler of resonator.
                Grover Beach, CA
                www.BimmerHeads.com
                • silversleeper
                  • Mar 2005
                  • 2032
                  Ah, gotcha.
                  yeah, that would be the way to go. maybe in place of the cat, use the rasp eliminators. they look like glasspacks from what ive seen.
                  • fretburnr
                    • Jan 2005
                    • 1496
                    I've got no cat - merged to a single 2.5 right after the downtubes, and a magnaflow resonator where the cat used to be... all back out to a magnaflow muff.
                    It's pretty loud - I have no problem being heard when I want to, but it's really not that bad putting around town.
                    It also doesn't have much rasp, at least not the e46 kind :p
                    Jay
                    • JoeMadoo
                      • 936
                      How can I quiet down my exhaust alittle bit? I have a single 3 inch from the downpipes to a magnaflow cat and magnaflow turbo xl. Will a resonator quiet it down a bit or should i just get a different muffler.
                      '86 E30
                      '05 E53 X5
                      '72 Firebird
                      '10 Prius
                      '03 Tundra
                        • 37829
                        If you're only wanting it a bit quieter just add a resonator or cherry bomb to the center section if there's room. Pep Boys actually has a large selection of cherry bomb mufflers and they're cheap too.
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • Vicarious
                          • 223
                          what do you guys with no cats do about emmissions tests? do you just go to a private shop and pay the guy off to give you a "Pass" sticker? in NJ ure gonna fail without a cat im almost positive.
                          • direction88
                            • Feb 2007
                            • 228
                            With clean oil and your EGR connected any reasonably maintained M20 will pass most emissions tests without a cat! However you may fail the visual inspection if they do one. I'm in Vancouver and the air scare tests are probably a bit different here but I hope this is still of some use.
                            "Drifting an E30 is like pouring out a beer just to get a nickel for the can"
                            • Mr.sexymorningvoice
                              • Sep 2007
                              • 402
                              Hey well i have a gutted cat, and 2.5inch all the way back into a 2ft glasspack, and it sounds good, nice deep tone, with a little rasp at 2k rpm, but overall it sounds nice
