Q: gasket/donuts for OEM cat-back?
  • funcrew
    • Jun 2007
    • 1223
    As an aside, I drove my 325 convertible to pick up a couple of newlyweds at the Las Vegas airport so they could buy my Toyota Echo. Both of them liked the 'vert, and the guy said, "That's a great exhaust note - is that a Borla? The guy and his wife loved it when I told 'em it was the 20 year old stock muffler with big rust holes.
    Anyway, I just received an installation kit to go along with a replacement OEM muffler/cat-back setup. The install kit came with two metal donuts of slightly different diameter that look to fit between the cat pipes and the muffler pipes. It appears that one is aluminum and one is steel - the aluminum one is half an inch thick but the steel one is about a quarter inch thick.
    Is that odd couple what's needed? Or do I need two identical of one type or the other? I'm going to be calling Patrick at BMA about some other stuff on Monday, but would like to figure it out before then if possible.
    Thanks!
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • JoeP
    • Mar 2005
    • 150
    Looking at Real OEM, the right one is 42mm and the left one is 45mm. Hope that helps.
    • funcrew
      • Jun 2007
      • 1223
      Thanks - then I'm in good shape as the ID's of the two pieces received are slightly different. Not sure why the donut diameter, thickness, and material would be different for the two pipes, but the E30 is nothing if not over-engineered.
      -Dr. Paul Forrester
