Exhaust Leak
  • cale
    • Oct 2005
    • 2331
    Exhaust Leak
    So I've started to develop a noise under the hood. Someone who heard it said right away it sounds like an exhaust leak. It starts as soon as I start the vehilce but is most audible when the rev's are dropping. It goes away when it warms up but comes back very quickly (2-3 minutes) when it's sat which leads me to believe the only thing that cools down that quicker are headers and exhaust so...how do I diagnose where it would be leaking?
  • Sean
    • 5793
    One way I've found leaks it holding my hand over the supposed area of the leak.
    Of course, the engine must be cold for this, and cannot be running longer than a minute. The headers are hot within a minute of running, so you gotta work fast.
    You can listen underneath the hood - exhaust leaks have a very distinct sound. I have a few on the underside of my car, and can feel them with my hand.
    - Sean Hayes
    • bmwboy325
      • Apr 2008
      • 1
      hey funny cause i am having the same problem did u get it fix
      there are two mental cover over the header leading to the cat was it that
      i do not have time to look at mine this week have to us my other car i order gasket but the way u guy put it .it sound like the gasket is not gone
      • cale
        • Oct 2005
        • 2331
        Found the leak was underneath the flexible connector where my exhaust meets the headers. Gonna take it in this week to have it repaired. Sounds kinda cool when you drive fast though, like a BOV when you shift
        • RobertK
          Kicked cancer's ASS.
          • Jun 2005
          • 5864
          Seafoam is the best way to find all your exhaust leaks. Suck some into a vacuum hose connected to your intake and white smoke will pour from all your exhaust leaks.
          • Sean
            • 5793
            THATS a good idea!
            - Sean Hayes
            • cale
              • Oct 2005
              • 2331
              Is it possible to replace the flexible joints between your manifold and cat instead of the entire cat? My exhaust was done only a few years ago so replacing the cat seems kind of redundant.
