My new Magnaflow mid section: http://www.discountperformanceautoparts.com/index.php?page=shop.product_details&flypage=shop.g arden_flypage&product_id=45971&category_id=9054&ma nufacturer_id=0&option=com_virtuemart&Itemid=37&vm cchk=1&Itemid=37
I’ve installed her now and I’m disappointed to say that it doesn’t line up precisely at the factory 3-1 collector flanges. On each of the two triangular flanges one corner is tight but a gap remains at the other two points. The flex pipe should ‘flex’ as to allow me close up these gaps, but I’ve torqued the flange bolts to the point where I’m worried I’ll break them if I tighten them anymore, and the gaps still remain. The rest of the system has only been hand tightened, so it’s not as though this piece is being pulled out of alignment.
So, questions:
Would it be reasonable/ advisable for me to use my torch to heat up the Magnaflow tubes just downstream of the flange in question & try to torque the flange bolts down more to close the gap?
Alternatively, should I perhaps heat up the flex pipe?
Are there any products I could use to cover this gap, like a crush-ring gasket I could install in the flange?
So, questions:
