California Certified Universal Catalytic Converter?
  • Conki
    • 1254
    I've been researching the topic, but I haven't found an answer yet.
    If there is another thread about it, excuse me for starting this.
    I have to get my '86 eta smogged in a month, and I'm looking for a catalytic converter.
    I haven't found a universal one that meets the new California standards.
    The only possible solution would be a direct fit cat from discountconverter.com for $400+.
    Is there any other way to acquire a legit converter for less money that passes both the visual and the emission tests?
    Thanks for your help in advance!
    1992 BMW 525iT Calypso
    2011 Jeep Wrangler
  • Stephen
    Шлем ишака
    • 10774
    Are they enforced yet? i had mine smogged around xmas time, with a universal weld-in cat
    • Conki
      • 1254
      The new law is enforced since January 1st, 2009 if I'm not mistaken... Realy a bad timing.
      2011 Jeep Wrangler
      • Jean
        • 18228
        Borrow someone elses?
        • mafoose
          • Apr 2009
          • 34
          Ha! In that case why not get some buddies together to pool for a "smog cat" then either make an x number of straight pipes or gutted cats for the rest of the time?
          • Conki
            • 1254
            I don't know anyone else owning an E30 around here. And actually I don't know anyone who's had their car smogged this year.
            I made a few calls and I was told that Magnaflow 36005 is one that would work, although I haven't found anything about that specific cat...
            2011 Jeep Wrangler
            • Conki
              • 1254
              I know it's bad for the environment, but I actually thought of that... Only if I had some E30 guys around here, just have a cat for smog checks in the storage room... As little I drive my car, I wouldn't hurt anyone with a trick like that.
              2011 Jeep Wrangler
              • nwind21
                • 3
                Any updates?
                My 1987 325is failed so I'm looking for a weld in cat to save costs. I was recommended some Catco but it looks like all the current weld-in universals don't meet the new Jan 2009 requirements. I wish I hadn't procrastinated and smog checked/fixed it before Jan.
                • e30this
                  • 3580
                  Check www.summitracing.com for converters for you CA guys.
                  I know Magnaflow makes a cat that works for the CA laws..
                  if you want to do a custom exhaust you can go with one of these.
                  I know they make a dual in and out one also. I have used it on my car too.
                  • Conki
                    • 1254
                    OK, so I just passed smog on Friday.
                    There wasn't really a choice, I had to take it to a muffler shop. They welded in a Magnaflow Cat. It cost me $219+tax, but at least I can get my tags tomorrow. Yay!
                    Before:
                    After:
                    2011 Jeep Wrangler
                    • B. Tyler
                      • 174
                      Which cat did you end up using exactly? Was it this one? I need to get smogged here too and failed by about 100 points.
                      • Jean
                        • 18228
                        Conki - cool! My numbers looked the same with 36008.
                        B.Tyler - he's got a 6 cyl, probably a different cat (most likely 2 in 2 out).
                        • guibo09
                          • Dec 2008
                          • 834
                          cats really make a difference. i wonder where a hiflow would sit.
                          90 E30 325i
                          • Conki
                            • 1254
                            I don't know which model it is exactly, the shop just put in a universal Magnaflow that's right for the 6cyl E30s.
                            2011 Jeep Wrangler
                            • tiresmokindad
                              • Oct 2009
                              • 1
                              Hello everyone.
                              Sorry for my ignorance, I really need help. I was confused if the magnaflow catalytic converter is pretty good?and also where to buy? I do some searched, inguiry and I come up with this Magnaflow Catalytic Converters . Anyone tried it here.? Any suggestions, please let me know. Thanks.
