Quick CCV/vac question for the guru's
  • 328ijunkie
    • May 2007
    • 3961
    How are you guys not puressuring the crankcase with the stock dump tube in place? im working on a car and cleaning up his engine bay (turbo M20) and just noticing some issues with it.
    Also will the stock ICV allow boost to bleed the wrong direction through it? Currently this guy is running the intake side of the ICV to atmosphere basically...
    and im assuming you should have the charcol canister vac line blocked off as well....
    Check Us out on Facebook
    Full Product Line Tuning
  • TS87325IS
    • Sep 2006
    • 821
    mine just runs to atmosphere too , left the charcol canister lines alone , am going to plum my ccv to pre turbo line soon though.
    mods: just meat and potatoes under the hood and wheaties on fire out back ;)
