E30 M50 Turbo manifold
  • SamE30e
    • Sep 2007
    • 4319
    Hey,
    Has anyone had success with using a Ebay M50 turbo Manifold on the E30. I know Otis makes a manifold but I don't have 700$ kicking around. I saw Yoshi's and his housing hit the valve cover. Are the Ebay manifolds meant to be bottom mount?
    Thanks
    Sam
    1985 325e 2.8 Turbo VEMS
  • shiboujin
    • Feb 2006
    • 2791
    yes they are meant to be bottom mount. even modded to be top mount, mine has cracked 3 times. Don't go ebay. shits too thin and shitty.
    • SamE30e
      • Sep 2007
      • 4319
      So why don't they clear as bottom mount? And has anyone tried the OBX ones?
      • shiboujin
        • Feb 2006
        • 2791
        allegedly the SPA ones will clear as a bottom mount. depends on what turbo you are using too. Much less room on the bottom of an E30. My ebay bottom mount and HX35 wouldn't clear as a bottom setup.
        • SamE30e
          • Sep 2007
          • 4319
          I have a HY35. I'll figure a way to make it fit top mount.
          • shiboujin
            • Feb 2006
            • 2791
            Theres a GB on top mounts. save up. its the most important part of your setup. I regret my ebay shit so bad.
            • SamE30e
              • Sep 2007
              • 4319
              Yea, I know Otis has one going. If it was a couple months later I'd be in for sure, but I just can't afford it right now with Christmas coming.
              • White325is
                • Oct 2006
                • 5947
                I have a top mount M50 turbo mani Id be willing to sell.
                I modified the flange to clear the VC and Body. Let me know I will snap some photos for you later today.
                • skatebline
                  • Sep 2006
                  • 167
                  Can we see the pictures anyway?
                  • richardb
                    • 2121
                    +1 on the pics
                    Transaction Feedback!
                    • SamE30e
                      • Sep 2007
                      • 4319
                      Can you post pictures.
                      I have an idea of what to do. Ebay manifold re-welded and buy 2 t3 flanges and make a 45 degree adaptor.
                      • White325is
                        • Oct 2006
                        • 5947
                        Pics...
                        • e30polak
                          • 6136
                          ^ That beauty is mine now! :D
                          I'm going to go over all the welds and have it jet hot coated. Hopefully that will keep it from cracking. (fingers crossed)
                          INSTAGRAM: @UNDR8D_EMPIRE
                          • Pudmunkie
                            • 210
                            Jet hot isn't going to stop weak metal from cracking.
                            • e30polak
                              • 6136
                              After looking into it further, I will probably just redo all the welds and create 1 or 2 support brackets for the turbo flange. The brackets will have rubber grommets, and will bolt on to the header flange. Hopefully this will help take some stress off the manifold, and absorb some of the vibration.
                              I just need the manifold to last atleast a year of abuse, then I will save up to buy the 666fab one.
