clutch question
  • jakeb
    • 1909
    clutch question
    I am going to be turboing my s52 in the summer and thinking of what clutch to run. I am currently running a m20 flywheel and stock m20 clutch. I am shooting for around 350whp on a stock obdI s52.
    So...will the m20 clutch hold it? I was thinking of a 6 puck and red PP from clutchnet but it is pretty pricey at right around $600 for a clutch setup.
    This is a DD so I would like a clutch that will hold the power but not something that is going to be a bear to use.
    If I should step up to a bigger flywheel I could do that.
    TIA....
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • Tchao
    • Apr 2007
    • 223
    If 400bhp is all you will be after, contact TCD for thier stg2 clutch, which is around $500 and drives like stock. Should hold ~450ftlbs
