Homemade Heatshield
  • IminDiegoTriick
    • Oct 2009
    • 1564
    Homemade Heatshield
    How do you make a heatshield and what materials do you use for it?
    Fast life fuck slow..Low life for life
    Let the mix flow..Let the night flow
    I'm so gone ✗ ♥ O
  • Rolla1990
    • 199
    First.
    Turbo M20, MSnS, 38lb, 3" no cat, RPI 12.2", ATS DTC, 240whp/240wtq, Lmnop. www.DonsGarage.net
    • mrsleeve
      • Mar 2005
      • 16389
      sheet metal is your friend
      Originally posted by Fusion
      William Pitt-
      • 4bangerfury
        • Aug 2009
        • 335
        gold. it's true. and it'll make your engine bay scream baller status.
        • E30Idea
          • Mar 2007
          • 2196
          Originally posted by Rolla1990
          First.
          one to be gay?
          ** Lot's of M20 turbo parts for sale.**
          Turn key track car.
          http://www.r3vlimited.com/board/showthread.php?t=222066
          • e34john
            • Apr 2006
            • 3599
            it is a really good heat reflector. i'd say he should do it.
            • Wh33lhop
              • 11705
              I don't know, but there definitely isn't enough pedobear in your sig.
              paint sucks
              • Be30mer
                • Jan 2010
                • 1121
                sounds expensive
                and if he says he can afford it
                You are lucky your Dad didn't pull out and leave you on the passenger side seat.
                • Iain
                  • Oct 2005
                  • 2815
                  Can you guys source this stuff over there?
                  ACL,performance,bearings,motorsport,engine parts,engine bearings,race series,main bearing,race bearing,con rod bearing
                  Used on a few Aussie OEM turbo applications and very popular with turbo boys over here...
                  Pork Hunt Motorsport
                  eBay is like the summit racing catalog for today's special Olympics crowd
                  • blueapplesoda
                    • Dec 2005
                    • 1904
                    there is a manufacture in socal that makes stuff similar. Also, the underside heatshields on e36s look similar.
                    • 619E30
                      • 1753
                      Stainless!
                      Originally posted by audiquattrot
                      bimmers b4 b*tches....remember that.
                      1990 Alpinweiss 325i - secret 500whp build
                      2000 Audi S4 B5 Laser Red
                      1990 Nissan 240sx - Drift Missile
                      2006 CBR600RR
                      • gearheadE30
                        • Jun 2007
                        • 3734
                        I actually used plexiglass and a heat gun to make a temptorary (but effective) one before all the turbo stuff is finalized.
                        Project M42 Turbo
                        • bear
                          • Jun 2010
                          • 191
                          fiberglass repair mat from an auto paint wholesaler i think its about 30$ for 4'x4' sheet
                          91 325ic
                          85 528e
                          92 325i
                          86 535i gone
                          92 325is gone
                          • GSM07challenger
                            • 671
                            here is a low budget and very effective idea if you are looking into creating a heat shield for your turbo. find an appropriate side pot and cut a strip out of the pot. This will already have the curved shape to cover the majority of your turbo, and the thickness stainless steel pot will be a great heat shield from the rest of the surrounding areas.
                            For further explanation and a pictures on the process please look at this post.
                            FS:///M-Tech Wallets.
                            http://www.r3vlimited.com/board/showthread.php?t=224601
                            • bear
                              • Jun 2010
                              • 191
                              ^that is a pretty cool fix
                              91 325ic
                              85 528e
                              92 325i
                              86 535i gone
                              92 325is gone
