Supercharging?
  • HarryPotter
    • Jan 2010
    • 3642
    Supercharging?
    I searched and there isn't much to read.
    I can fabricate a bracket. I just have no idea what kind of supercharger to get, or where to get em, or what type to get TS, centrifugal, stuff like this...
    Does e30tech have any more info on this type of stuff?
    John F. Kennedy
  • GOOBER
    • 663
    There's some info out there (some guy on e30tech had a nice set up from sweden). Depends on the use, for a daily driver most will say a twin screw. Its more then just fabricating a bracket. You need a wide band o2 sensor, a rising rate fuel pressure regulator and some piggyback to retard ignition timing at a bare minimum. Full standalone engine management would be ideal. Like many people will tell you, supercharging is easy to install but difficult to master...so most people will tell you to just go turbo because it's better bang for your buck.
    • blalor
      • 217
      GrassRoots Motorsports did a supercharger install with an outfit in Atlanta (DASC, I believe).
      http://grassrootsmotorsports.com/pro...991-bmw-318is/
      • blalor
        • 217
        grrr, 6am server-maintenance-induced double-post.
        • ethree
          • Aug 2007
          • 1213
          Need a clean M90?
