Need help with turbo build on a 91 e30 m42
  • autobot_lazi
    • 50
    So I had some questions regarding turbo'ing my 91 e30 with an m42 motor.
    So this is what i have so far..
    turbonetics t3/t4 turbo
    turbonetics wastegate
    drag intercooler and piping
    blitz bov
    Apexi AFC neo
    AEM wideband EUGO
    Apexi avcr
    oil lines and pumbing
    This is what i am getting or need custom made
    Downpipe
    1) My question is will the afc be good enough for tuning? or would I need to go stand alone. If I need to go stand alone what would you recomend for a novice . anything fairly decent in price and easy to use?
    2) Does anyone have a used stand alone for my car that they are willing to part with?
    3) Which injectors would you recommend?
    4) How many lbs of boost would you recommend? I was thinking 9lbs. is that safe?
    5) anything else i would need?
    6) are there any shops in the area that can do the tuning? anywhere between los angeles and san bernardino to orange county
    Thank you in advance guys
  • fiftytakedowns
    • 2460
    m42s can take 14lbs safely.
    I would go with a Plug n Play Megasquirt and use that.
    [/url]
    Team USA Wrestling 67KG
    • autobot_lazi
      • 50
      Does anybody know a shop that can install and tune the car? I was leaning toward megasquirt. I just dont know any bmw tuners.
      • omar85
        • 331
        a turbo manifold a lot more research on the subject before committing to anything.
        • autobot_lazi
          • 50
          I have a good n tight manifold. i forgot to list that. I think my main issue is in the tunning. I can get everything installed with no problems. But i dont know any bmw tuners. most likely i will be going megasquirt.
          • Schnitzer318is
            • Jan 2008
            • 2057
            If you go MS, I can give you a copy of my .msq that will get you started. That being said, you can teach yourself MS in a couple of weeks. I tuned my car myself after getting started with a base map from DTM (built the pnp MS).
            After you have MS installed, any tuning shop can tune it. It is just a MAP based ECU so it shouldn't be a problem if you wanted it dyno tuned. Would be expensive though... that kind of dyno time isn't cheap.
            "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
            91 318is Turbo Sold
            87 325 Daily driver Sold
            06 4.8is X5
            06 Mtec X3
            05 4.4i X5 Sold
            92 325ic Sold & Re-purchased
            90 325i Sold
            97 328is Sold
            01 323ci Sold
            92 325i Sold
            83 528e Totaled
            98 328i Sold
            93 325i Sold
            • autobot_lazi
              • 50
              that would be great. Thank you very much
              • adr1an
                • 1
                Megasquirt for E30 M42
                They do have a plug and play for the 318is? I've been looking and couldn't find it. Also i wouldn't mind grabbing that .msq file to help me out with a base tune.
                Thanks
                • Schnitzer318is
                  • Jan 2008
                  • 2057
                  ^It's on my turbo build post on one of the last pages. There is alink to it in my sig.
                  91 318is Turbo Sold
                  06 4.8is X5
                  06 Mtec X3
                  05 4.4i X5 Sold
                  90 325i Sold
                  97 328is Sold
                  01 323ci Sold
                  92 325i Sold
                  83 528e Totaled
                  98 328i Sold
                  93 325i Sold
