On diyautotune.com they offer the MegaSquirt-I Programmable EFI System PCB3.0 - Assembled Unit.
Then they offer MegaSquirt-II EMS System - SMD PCB3.57 - Assembled Unit.
I was just woundering which one would be the easier rout to go? I mean just to go with a EFI system or EMS when thinking about wiring and tunning. I am not a big fan of wiring so the least is the best. As far as these assembled units go has anyone ever used these units? Im running 8-10psi on 60k stock m20b25 with bigger injectors(of course).
Also i have been reading lots about running stock head gasket with arp studs, which was what i was planning on doing, but what is the deal with MLS headgaskets besides lowering compression? Do you have to weld the water jacket grooves to be on the safe side?
Sorry so many questions just read so much and get two diffrent sides on somethings (time to turn to oppinion).
