Just curious as to how much boost a stock head gasket on an s52 motor can handle? I am about to purchase a stage 1 supercharger and only plan on running like 8lbs of boost. Nothing crazy. It's only a weekend car. I just don't want to go through the hastle of replacing the head gasket. Thanks in advance.
head gasket
Tags: None
You'll be fine, just get arp (or arp2000) head studs and you are golden. Preventing blown hg's on m/s5x type motors is all about preventing cylinder head lift with copper, MLS, or even stock. -
Cometic MLS and ARP studs.
If you're going FI that is the best way to keep things together aside from o-ringing the head.sigpic
Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677Comment
Traditionally the block I'm told, within the tuner circle the head seems to be more common... I think the head o-ringing started with cast block/al heads and their different expansion rates etc. My head is o-ringed, not my block, for this very reasoning.Comment
I've done two blocks with no problems so far.Comment
