Turbo M20 Build
    Slick work my man. Thanks for the pics!
    -Greg
    90 325isT - 12.2 @ 120ish - Dyno Results
    b18c5 EG Coupέ - 13.5 @ 100ish - Dyno Results
      Any reason to do this? looks good though.
        Can u check and see if there's cracks on the stock mount?
        Mine is cracked just wondering if it's "normal" in that area.
          Thanks greg...no thread is fun if you have no pics lol
          I plan on increasing my traction so don't want to deal with having the stock mounting point to rip out. I'm also hoping it reduces diff movement to help with wheel hope.
          Mine isn't cracked at all i guess i got lucky cause i don't drive my car easy.
          Update: Got it all welded up...ready for paint then new trunk floor.
          Build Thread
          http://www.e30tech.com/forum/showthread.php?t=84988
          "When In Doubt Boost It Out"
          ~89 325I Turbo 11.90 @ 121~
          ~ 420whp/420tq~
          15psi
          ~Paul Burke Built 2.8L Stroked M20
          ~666 Divided Mani T3
          ~6262 T3 Turbo
          ~O'ringed Block SS
          ~Custom Fuel System
          ~3'' Turbo Back
          ~50mm Tial Bov
          ~Dual Tial 38 Gates
            how did i miss this?? awesome stuff! keep it up man!
              Just wanted to say...I hate you.
              Seriously though, this is an incredible thread man. Absolutely beautiful car and build.
                Great build just read through all the pages!
                87 BMW 325 is
                  Thanks for the kind words guys...here's the diff cover all painted up and revshift bushings installed
                  Build Thread
                  ~ 420whp/420tq~
                  15psi
                  ~6262 T3 Turbo
                  ~O'ringed Block SS
                  ~Custom Fuel System
                  ~3'' Turbo Back
                  ~50mm Tial Bov
                  ~Dual Tial 38 Gates
                    Freebie...1 3/4-1/8th thick mild steel roll cage tubing for rear shock tower brace I'm building. 24' total of tubing need to clean the surface rust off. After everything is all done I'm painting the entire trunk black.
                    [URL=http://s692.photobucket.com/user/Cesar85/media/7E24A67C-15E3-46DF-9D30-45784B408D1C.jpg.html][/URL
                    Build Thread
                    ~ 420whp/420tq~
                    15psi
                    ~6262 T3 Turbo
                    ~O'ringed Block SS
                    ~Custom Fuel System
                    ~3'' Turbo Back
                    ~50mm Tial Bov
                    ~Dual Tial 38 Gates
                      Started working on my catch can...lets see if this works like i plan too. Will be adding steel wool on the second port area on the left.
                      Catch can is now mounted and waiting on powder coat for new valve cover and can...
                      Build Thread
                      ~ 420whp/420tq~
                      15psi
                      ~6262 T3 Turbo
                      ~O'ringed Block SS
                      ~Custom Fuel System
                      ~3'' Turbo Back
                      ~50mm Tial Bov
                      ~Dual Tial 38 Gates
                        You're a damn good TIG welder... That is all :p
                        A man chooses, a slave obeys... Would you kindly?
                          outstanding job on that catch can.....I will be building my own as well. What thickness of aluminum did you use? I have some 18ga laying around I was going to throw together. Also, what tig-rig do you have? I don't think I saw it in any pictures.
                          Instagram @rebellionforge
                            Thanks guys...im using regular 6061 aluminum rod. I used .090 thick aluminum plate.
                            Build Thread
                            ~ 420whp/420tq~
                            15psi
                            ~6262 T3 Turbo
                            ~O'ringed Block SS
                            ~Custom Fuel System
                            ~3'' Turbo Back
                            ~50mm Tial Bov
                            ~Dual Tial 38 Gates
                              Where did you pick up the piping for the intercooler etc? I plan on doing the same and having very few silicone connectors in my setup.
                                I get all my piping from Verocious motor sports
                                Build Thread
                                ~ 420whp/420tq~
                                15psi
                                ~6262 T3 Turbo
                                ~O'ringed Block SS
                                ~Custom Fuel System
                                ~3'' Turbo Back
                                ~50mm Tial Bov
                                ~Dual Tial 38 Gates
