I have a 2.5 i engine and I am having alot of trouble finding a good price on intake piping and a place to get my fitting's from the oil presure to oil dump I try'd local machine shop's and there no help also has anybody herd of a good wastegate and bov for under 200 dollars?
turbo fitting's
Get pipes on ebay. Just make sure that you rough up the aluminum on the ends or you'll be popping off pipes rather often.
Used Tial 38mm wastegates are pretty common, and they're bulletproof. I bought by BOV from ebay seller wyntonm. Make sure you get one that is adjustable. For an ebay seller, I was very impressed with his products. $80ish iirc for the BOV and the adapter pipe.
I can supply you an oil feed adapter and feed line for $55 shipped. For intake piping get the cxRacing stuff. Thick enough to weld and it comes with good couplers and t clamps. Wynton sell good stuff. Don't buy the other greddy typs s knock offs cause the vacuum input is not airtight and will make it harder to actuate quickly causeing compressor surge.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
I'm considering changing over to a precision power wastegate so my tial 38mm will be up for grabs soon.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
cleaned up pm boxYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
